Most of my vehicles over the years have had a manual transmission, usually to have more gears than was possible with an automatic transmission. My current truck has the GM Grade Control and it has a 6-speed transmission. It works perfectly.
I have done descents of 10 miles on grades that went from 6% to 8% and kept the truck at 35 MPH without touching the brakes. Going into a section where I needed to go slower still all I have to do is tap the brake pedal and the transmission downshifts and maintains a slower speed. It ONLY works with the transmission in auto mode. Put it into manual selection and the grade control is disabled - which I would bet many owners do not realizing that they have disabled this function.
An automatic transmission can allow for some slipping and shock absorption that if done with a manual transmission would damage the synchro gears or the clutch or both. For offroad excursions I prefer a manual transmission and a clutch but for towing an automatic is the better choice.
A secondary consideration for people towing a camper is the power lost while shifting with a manual transmission. The newest tractor rigs are coming with a new type of transmission that allows for constant power during gear changes to avoid the loss of power and wasted fuel.
With my Chevy truck I have the Grade Control, an exhaust brake, and tow/haul mode and a trailer brake controller which can be used individually or together to provide a great deal more control when towing if used properly. These systems do still depend upon the person behind the steering wheel.
