BenK
May 02, 2013Explorer
This is the main herd that you guys are now part of...albeit you are
more knowledgeable, but never the less, part of their herd...they out
number you and me, therefore drive the OEM marketing's option
availability list
The automatic is doing what it is designed for...clueless folks, but then they
question if it is okay...or that they have cruise on and it *WILL* drop down
to 1st or whatever trying to maintain whatever speed dialed in
That is the driving force behind automatics... IMHO
Why I can NOT order a manual for my Sub when I filled out the order form
Even had the dealer (they sold semi's and pickups's as a service to their
trucker customers called to see if there is anyway the factory would
stuff in a manual...we both knew better, but gave it a try
http://www.rv.net/forum/index.cfm/fuseaction/thread/tid/26913637/srt/pa/pging/1/page/2.cfm
AND this one...asking if they should lock out either or both of the
double OD's...or didn't know to engage tow/haul...heavens...it is an
*AUTOMATIC* so let it do it's thing and stop asking manual tranny
questions...oh, but the tow/haul button is manually initiated and they
have to 'think' about that...betcha it's going to become an automatic
feature soon along with the increased cost and complexity of the
strain gauge system....oh my, then they can see that the strain gauge
can be highly integrated into the whole vehicle to have the main
computer know when it has been over loaded... :R
http://www.rv.net/forum/index.cfm/fuseaction/thread/tid/26914934/srt/pa/pging/1/page/1.cfm
Again, these types are what the main herd is made of and drives the
OEM's option list and the more they pay willingly, the more automated
it will become
availability list
Greetings,
I just made my first trip into the hills with my new 2 me fiver and my new 2 me truck. We are talking Texas hills, so they were not extended lengths, but there were some 7% grades that were probably a couple miles long.
I have the SRW F350 6.4L and I am pulling about 10,500 plus 4 people and a couple hundred pounds in the truck. I set the cruise on 64 - 66 for most of the trip. I run about 1,700 rpms and about 17 lbs of boost in normal running with the fiver.
Here is my question: When I hit a couple of those hills, the rpms jumped to 2,300 and the boost jumped to near 30 lbs. The truck held the cruise speed. It was not hunting for a gear or anything like that. It just shifted down, and kept the speed. Is this okay? Or should you back it down?
I have towed around Houston quite a bit now, and I am just not used to hearing the engine work that hard, even though it did not seem to be in a bind.
Thanks for the replies.
it will become
