Charliegu58's avatar
Charliegu58
Manufacture Assigned Weights
I have a 2011 Veiwfinder 22RBDS and the 2011 brochure for this trailer model states the following weight numbers.
GVWR 6,095 LB
Axle Weight 4,095 LB
Dry Weight 4,535 LB
Cargo Capacity 1,510 LB
I was looking through my manufacture documents and came across the weight info which stated the weight info above was listed on the Weights Tag, Tire Loading Tag and the Dry Weight on a sticker inside a cabinet door. Well this is what I found.
GVWR 6,095 LB
GAWR 4,465 LB (I assume GAWR is the same as Axle Weight in brochure)
Dry Weight ????? LB (No Sticker)
Cargo Capacity 1,135 LB
The dry weight sticker is nowhere to be found. I looked in every cabinet door, inside and out. I looked in and under every drawer.
I only have about 600 LB of cargo, but I don’t like the fact I’m that close to the GVWR. Also, I’m concerned there is no Dry Weight Sticker as well as the axle weight is so far off.
I have emailed Cruiser RV to explain these differences. I have included the trailer VIN.
Any thoughts….
