Dog Trainer wrote:
I would not even think about pulling a trailer with an engine with that much modification. There is no certification available for tow specs. A Chrysler hell cat has over 700 HP and it won't pull your trailer across the street. Maybe start by reading many posts and searching topics that will get you pointed in a right direction. BTW HP is always the result The formula result of Torque and RPM's.
Wow, that's quite an interesting comment. Why would you not think about pulling a trailer with that much modification? Do you think modification = less reliable? Could be, but that's all about the builder. I could argue that a highly modified engine could be more reliable than one built at the factory, given quality parts and a quality builder were used. Of course a Hell Cat couldn't pull it; it has no payload capacity. I would say a 3/4 ton has a bit more payload than a Hell Cat... ;)
