Dave Pete wrote:
So what was the resolution?
I tested at the pump with switch on and got no juice! Called & emailed Lance but got no response which really helped right? Called the monitor mfg. that is listed in the owner's manual. They said that they only made some components so couldn't really tell me how it was connected behind the face plate. Went and picked up some more fuse's (7.5a for pump, 3a for monitor panel). Replaced the fuse's for both circuits again(2nd time), bingo! I had already made an appointment at a dealer for service as I had a couple of other maintenance discrepancies I wanted them to remedy. They couldn't provide an answer either and didn't have any idea on how the two could be linked. Anyway everything has worked fine since. I did decide to buy a replacement pump to have as a backup given the age of the OEM and that it has had plenty of use. If it's going to fail I know it'll happen when boonin' somewhere!
Oh and I did not pull the face plate on the monitor which would have given me/us a better understanding of how it's wired. Just didn't feel a need once everything was back on line.
