GULFMAN's avatar
GULFMAN
Explorer II
Dec 03, 2018
mattress moisture barrier
Just Curious does any of you use a moisture barrier under your mattress?
  • Pangaea Ron wrote:
    A similar material is available at building supply stores for the exterior of concrete foundation walls to control water intrusion/pressure, and might be cheaper.
    EDIT: It's called EnkaDrain.
    that looks like the stuff I used, only the person I got it from said they put it over plywood before putting stucco on.
  • markchengr wrote:
    X2 on Hypervent, it made a world of difference. Expensive, but money well spent.
    X4
  • A similar material is available at building supply stores for the exterior of concrete foundation walls to control water intrusion/pressure, and might be cheaper.
    X3 - worked really well in our truck camper. Never found the need for it with our Class A or B+ though.
  • X2 on Hypervent, it made a world of difference. Expensive, but money well spent.
  • DEFINITELY! (I changed out my OEM mattress to a latex mattress duplicating home) Hypervent from Fisheries Supply. Purchase by the foot (queen mattress will require two strips - therefore buy 2x length of mattress). I also use it on home bed, as I was starting to see mildew on mattress surface against plywood bed board.
