- wmosesExplorerInstalled my Fantastic Vent today at the campground. Now my Fantastic Fan in my rear living area is covered and come milder weather I can leave it open all the time. :)
- zackyboy3rsExplorerDid both today.
wrvond wrote:
Just for clarity, I'm going to refer to the little plastic square thingy that sits atop the vent opening that is cranked up and down to allow air in or keep it in as a vent lid, and those big ol' plastic thingies that look like little dog houses that sit on top of vents that allow you to keep the vent lid open while it is raining outside and not let the rain inside, as vent covers.
If you have lost your vent lid, it is possible to purchase and install a replacement lid. However, this endeavor is fraught with difficulties and pitfalls. You need to know what brand and size vent/lid you had up there before the catastrophe. Not all vent lids are created equal. Also, you are going to have to climb up on the roof to verify that the departure of the old vent lid did not cause collateral damage. IMHO, it is much easier to simply replace the entire vent/lid assembly. There are installation instructions with the new kits, plus many youtube videos.
Once you have installed or repaired your vent/lid, you may want to install a vent cover. A vent cover is "aerodynamically" designed to not catch the wind while the camper is rolling down the road. On the "tall" side it has a louvered vent. This allows you to leave your vent lid open and protected from most water intrusion (though I've seen heavy rains that blow in or splash a lot of water in). The vent cover does not mount flush to the roof, so why they put bug screens on them is beyond me. One thing to be aware of - the manufacturer of the Fantastic Fan vent says that a specific vent cover is required for their vent, but many have reported no problem installing the popular Maxx Air vent covers over the Fantastic Fan vent.
Maxx Air does sell a vent cover that has it's own fan built in with a very acute, downward facing angle to it's face that promises to keep pretty much all water out. But, as noted earlier, it is pricy.
I hope this clears up the OP's question. - wrvondExplorer IIJust for clarity, I'm going to refer to the little plastic square thingy that sits atop the vent opening that is cranked up and down to allow air in or keep it in as a vent lid, and those big ol' plastic thingies that look like little dog houses that sit on top of vents that allow you to keep the vent lid open while it is raining outside and not let the rain inside, as vent covers.
I hope this clears up the OP's question. - GrandpaKipExplorer IIFYI----Create a Breeze is a Fan-tastic fan. Just one of the models. Best fan going, I believe. Like the made in USA, too.
- CavemanCharlieExplorer III
westend wrote:
rexlion wrote:
Hey, you should have left that line for CavemanCharly. :B
Installation was so easy, even I was able to do it!
That's what I was thinking.
But, I never have installed one. Though about it but, it just more money I really don't need to spend. Would be nice though. - BumpyroadExplorer
zackyboy3rs wrote:
Bumpyroad wrote:
by vent cover are you talking about the one that cranks up and down, which is what it sounds like in your explanation, or a cover that fits over the entire fitting so you can crack open the vent in the rain?
don't know why the loss of a maxxaire type of cover would cause water to come in since you could just crank down the lid/cover.
bumpy
Sorry. The lid broke off sometime recently.
OK, that changes the entire discussion. your first stop should be to get just the lid replaced, available at any RV dealer, I think there are about 3 different styles so be sure you know which one you want/need. and then cover it with a maxxaire type of cover.
bumpy - zackyboy3rsExplorer
bumpy
Sorry. The lid broke off sometime recently. - BumpyroadExplorer
PawPaw_n_Gram wrote:
The standard MaxxAir cover is really for unpowered vents. The external cover which allows you to open an unpowered vent when it is raining, and to shade direct sunlight from the actual open vent.
You want a better fan vent - Fan-Tastic and Create-A-Breeze are the two biggest names in the field. .
I am talking about the Maxxaire cover that has the fan in it. it was a snap to install. mount the same using the 4 L brackets as any other vent cover, and hook the wiring up to the wiring for the little whirr and buzz.
bumpy - fallsriderExplorer
Bumpyroad wrote:
We know that already. Don't ask us how we know. :S
if you do put a good fan in the bathroom, do not have it running with the door closed while you flush the toilet. if you do the black tank will vent up thru the bathroom.
We rented a 27' TT right before we bought ours. It had a very good bath vent. We learned the hard way that you don't run the fan, with the door closed, and flush the toilet. Phew! :) - PawPaw_n_GramExplorerThe standard MaxxAir cover is really for unpowered vents. The external cover which allows you to open an unpowered vent when it is raining, and to shade direct sunlight from the actual open vent.
Fan-Tastic has a good reputation and a strong following. I really haven't heard anything bad about Create-A-Breeze but I don't see/ hear about as many rigs with them.
Powered vent installation is a bit more complex than adding a vent cover like the MaxxAir.
If you are replacing a powered vent - the wiring part is usually simple. The opening in the roof should be the same size and it's a matter of taking out the old vent frame, installing the new vent frame and water proofing the roof area around the frame.
MaxxAir does sell a vent cover designed for the greater air flow of a powered roof vent. It runs 2 to 3 times as much as the unpowered vent covers price wise.
44,070 PostsLatest Activity: Aug 05, 2026
