ktmrfs
Dec 12, 2017Explorer III
Ron3rd wrote:
My trailer's Alloy wheels are 15 x 6, 5-lug. The load rating stamped on them is 2150 lbs. It came with 225-75-15, load range C tires, which run 50 psi. These tires are are marginal IMO for the trailer which has a gross weight of about 8600 lbs.
When I replace the tires, I'd like to go with load range D tires that run at 70 psi. How do I know from the specs on the wheel if they can handle the higher psi?
they are good to the load specified. so if the load range D are 2150 lbs or less at max pressure you are good to go.
It's common that the 5 lug wheels are good for LRD and the 6 lug to LRE.
If they are steel wheels they sometimes have a max pressure stamped on the as well.
44,071 PostsLatest Activity: Aug 30, 2026
