RSD559
Jun 14, 2018Explorer
Max Tow F150s
How can I identify a Max Tow F150 by decoding the VIN? I'll be replacing my 2012 F150 with a newer one in the next 6 months or so. I'd like the heavier duty package when I do. But how does Ford ide...
demiles wrote:
If you would check what characteristics make a TV more stable , payload rating is not one of them. The only place it helps is in the vertical plane which has little effect on sway stability. The single thing that improves stability the most is increasing TV unladen mass followed by increasing its wheelbase. The Ford HDPP 150s are still lightweights and towing with high tongue weights and high payload is a scary thing. There’s a very good reason why HDPP tow ratings are lower. So the 1/2 vs 3/4 ton argument is valid though many don’t understand why
