RSD559
Jun 15, 2018Explorer
Max Tow F150s
How can I identify a Max Tow F150 by decoding the VIN? I'll be replacing my 2012 F150 with a newer one in the next 6 months or so. I'd like the heavier duty package when I do. But how does Ford ide...
Maury82 wrote:Samsonsworld wrote:
Reminds me of back in the day. I hate helmets. I used to wear shorts and nikes when out riding my atv's. Heck, a shirt was optional. I knew other guys that would come with helmet, goggles, roost protector, gloves and boots, even when it was 100 degrees. I dressed for the ride. They dressed for the wreck. It's a wonder I'm not dead, and looking back....it's hard to say they were wrong.
You might get away towing heavy with a half ton. I got away with that too, for years and years. But it's still hard for me to say the other guys are wrong.
Now one of my F150's is 4800 lbs. My F250 is 7200 lbs. With a large travel trailer behind you, which do you think is going to handle the load better when it hits the fan? I think that's what drives most of these guys. They're simply dressing for the wreck, not for the ideal situation.
I get your point, but there is one problem, you only say that when it's a 1/2 ton or below vehicle towing that 80% safe zone you guys once claim was a good safe cushion, but you won't say you need a 4500/5500 when the trailer is 80% of he 2500/3500 ratings.
How much cushion do you need for that 14,000lbs TT rated 2500...probably none.
I've never heard anyone questioning maxing over those low 2,000lbs payload 2500 diesels, or the those inadequate gas 250 straining to tow against its ratings.
Which huge cushion are we going to proclaim we need?
Keep in mind, many 1/2 ton owners are convinced most have flat out bias against the 1/2 to, and it is apparent that any and every excuse will be used as to why folks need a 3/4 ton for anything over a pop-up.
I'm placing my bet on Ford engineering and owners who tow heavy with HDPP truck, and I think they know a lot more than you guys do about its capabilities.
