Old-Biscuit
Jan 29, 2014Explorer III
hmknightnc wrote:
As others have said you are limited by tire capacity with a SRW 1 Ton truck. It highly depends on the truck and gear you have in the truck but as a general rule with a 1 Ton SRW you should stay below 14k# GVWR of a FW, for a 3/4 Ton you are looking at no more than 12k# GVWR FW. The trailer you are looking at is squarely in Dually country
There's the MFGs published specs and numbers and then there's the real world........
The above quote is in the Real World.
I get a chuckle when folks post MFGs. published numbers without posting ALL the little caveats/footnotes that are noted in the tiny print.
By the time the truck is optioned out and one actually goes across a set of scales loaded up camp ready they can't believe the numbers.....where did all that payload capacity go? what happened to that magical tow rating? my tires can't handle that kind of weight?
the truck weighs more than the sticker? Bah.bah.bah......
I wish MFGs would not publish any numbers and just state.........you need to weigh your truck in order to know what it can carry and/or haul!
