APT
Jul 26, 2019Explorer
My TT is 32' plus another 18" when the rear rack is extended. It weighs 5500 pounds dry, and I expect 6500-7000 pounds loaded depending on the trip. I towed it for 2 seasons with a 2003 Supercrew F-150. When my WDH was adjusted properly, it towed comfortably at 75mph. I now tow with a 3/4 ton Suburban with 600 pounds more payload, but 8" shorter wheelbase. Same trailer still tows well at 75mph.
Length is not really an issue. 7000 pounds and 33' or 7000 pounds and 30' will tow very much the same. Longer is usually easier to back up. Just keep in mind any what site you will fit into. Paylaod when loaded up is usually the problem with 2010+ half tons. What does your driver's door label Tire and Loading sticker list your occupant weight as?
