Huntindog
Jun 30, 2015Explorer
Cecilt wrote:Both.nevadanick wrote:My question then is what benefit is an E over a D if you do this? Don't you effectively give up all the extra load carrying capacity and in essence just have a Load D or is the E still a better and stronger tire at 65 than a D at 65. tks
On my tt i ran 65lbs in my Maxxis E rated and it rode fine.
The extra capacity can come in handy. I recently spun a bearing, and lost a wheel. The 3 tires remaining got us home without a hitch. They were @ 80.
You had them balanced. Did you make them use a lug plate? They hate doing it. I watch them to make sure they do it. More than once I caught them using the pilot hole instead of the lug plate as I requested.
The reason this is important is that most TT rims are lug centric. Not pilot centric. This means that the lugnuts do the centering, not the pilot hole which is not perfectly centered.
If they use the pilot hole, then it may well make the balance worse.
