MM49
Jul 02, 2015Explorer
lbrjet wrote:I agree with your rationale. Your logic sounds good, but it doesn't line up with reality. The amount of belts in the two tires is the same. The D and E tires are the same construction. The materials are different
I went from C to E rated tire last year. I run them at 65 which is the max pressure for my rim. My rational is the E has two extra belts over the D and hence a stronger tire. You don't gain any load capability (which I don't need, a D tire would give be me plenty of reserve capacity) with the E at 65 vs the D at 65, but you do have a stronger tire.
I have put 8000 miles on these tires and noticed no difference in ride at all.
MM49
