MM49
Jul 03, 2015Explorer
Huntindog wrote:MM49 wrote:Huntindog wrote:Your really good at making overly broad statments. You don't know the strength of the old 8 ply tire or the new one.Neither do you. You understand my point just fine. You are still just trying to split hairs for some reason. It wasn't that long ago that there wasn't even tire ratings as we know. During that time all tires were ST style construction. There is a need for ST tires in trailer usage with all their trade offs.MM49 wrote:It's spliting hairs.goducks10 wrote:The ply or belt is a strength rating. It doesn't relate to a physical count of belts. Again the D and E tires are virtually identical in appearance and weight.
What's the difference between ply's and belts? The D is 8 ply and the E is 10 ply. Surely 10 ply's are better than 8.
MM49
Years ago, an 8 ply tire had 8 plies, and a 10 ply had 10.
Now they go by ratings an 8 ply rated tire won't have 8 plies in it, but will have the strength of an old 8 ply tire.
What hasn't changed is that a 10 ply rated tire WILL be stronger than a 8 ply rated tire.
MM49
Unfortunatly tire construction is splitting hairs. A differnce in cord diameter or a rubber liner at cord intersectoin does make difernce. There will be trade offs with each method. My advice would be go with a proven brand like Maxxis that has made all those decisions and tested and validated the results. You will benifet from using a tire that is designed for trailer use application, yes there is a differnce.
MM49
