Cecilt's avatar
Cecilt
Maxxis Load D To E - Bouncy Ride
Had maxxis load E's mounted and balanced to replace my factory D's. TT weighs about 9500 loaded but wanted peace of mind. Drove home and ride was bouncy and I could feel it in the drivers seat. Called back and they said they balanced out fine, no tire flat spots and rims were all good. They aired them up to 80 psi per my request. Told them I was going to bring back to have them re look at the balancing.
They called back and said that I should air down to 65 psi to soften ride since that is what I had before. I said if I did that I would lose the benefit of having an E tire. Is that even correct to say. They said it will be a sacrifice of a stiffer ride at 80 and more weight carrying capacity on the tire of a softer ride and not getting the full benefit of the E's capacity.
I don't know if I should believe them so I am asking you folks. Please advise what I should do. I don't mind going to 72-75 psi but at 65 I could have stuck with a D tire. Thanks
  • At 65psi the "E"s can carry the same load as the "D"s.
    What benefit do you think the "E"s at 80psi will give you?
