gitpicker2009's avatar
Jan 31, 2020
maybe add some heavy duty pressure treated lumber?
I recently had to remove the bottom of my AF1150 in order to find a small water leak. In doing so, I was surprised at how little there actually is between the outside and inside. Basically there's an 1/8 sheet of black painted wood, similar to a good grade of wall panel, painted black (maybe some sort of water proof paint?) and that's it. the next thing is standard insulation sort of stuffed between wooden slats. I was really surprised. The weight of the coach therefore seems to be supported by the aluminum frame, which I've notice has some minor deformity where it reaches the edge of the truck bed.
When I reassembled the TC, I replaced the wood with the same and painted it with the best waterproofing paint I could find. But still I was thinking that when it rains, this this is basically sitting in the water until the bed drains.
I'm still not happy and was thinking that maybe I would just add some pretty thick pressure treated plywood under the entire coach. That would keep the TC slightly out of water and would distribute the weight so as to not put the load at the edge of the truck bed. I wouldn't even bother to paint it probably.
Any opinions or advice? Has anyone ever done anything like this?
I realize it's maybe another 75 lbs of weight but I'm driving a 2008 Sterling 4500, which is a beast.
Thanks for any input.
  • Don't use PT wood on TC.
    The chemicals are poison and should not be installed in human quarters.
    I am visual guy, so have hard time to imagine what you are talking about without a picture?
    Most of TC have only aluminium skeleton, where lot of wood is still load-bearing.
    That said, I had to shim my Fleetwood to go over new Ford sides, so having signs of weakening floor, I just screw 1/2" plywood under.
    I live in dry climate, so water protection is not important, but you can use deck sealer for water protection.
