- TvovExplorer IIThe website shows a hitch with weight distribution.
- valhalla360Navigator
QCMan wrote:
That is a typical European/Australian trailer hitches. They work with smaller trailers that are well balanced fore and aft as it is not a heavy load bearing hitch and is not a weight distribution hitch. Here it could (if it is truly DOT certified) be used on teardrops, smaller popups and some small lightweight travel trailers.
Never seen one in Europe. They typically use a ball style, just the shank is typically curved and permanently bolted on rather than the receiver style you see in N. America. - RobertRyanExplorer
QCMan wrote:
Wouldn't a hitch for heavy trailers need a way to distribute weight?
Yes. European lightweight Caravans do not have WDH. Australian and American do - QCManNomad IIIWouldn't a hitch for heavy trailers need a way to distribute weight?
In a word no. It is used for much heavier Caravans. Black series sold in the US would be exampleOur 23' Kedron ATV weighs in at 4.2 tonne or 9259lbs, with the capacity of the 6 tonne or 13227lbs McHitch makes it legal, safe and a pleasure to tow
Second Chance wrote:
Out of curiosity, what is the coupling for? Just looking at it, is it a fully articulated coupling for off-road use with lighter pull-behind trailers?
Rob
Not lighter Caravans. Yes for Off Road use - QCManNomad IIIThat is a typical European/Australian trailer hitches. They work with smaller trailers that are well balanced fore and aft as it is not a heavy load bearing hitch and is not a weight distribution hitch. Here it could (if it is truly DOT certified) be used on teardrops, smaller popups and some small lightweight travel trailers.
- Second_ChanceExplorer IIOut of curiosity, what is the coupling for? Just looking at it, is it a fully articulated coupling for off-road use with lighter pull-behind trailers?
Rob
