JEBar
Jul 28, 2014Explorer
06Fargo wrote:
The suspension switch on the dash could be a dump valve to deflate (drop) the suspension. This plus an air adjustable 5th wheel ("hitch") will be nice for coupling / uncoupling operations.
ours has the switch to dump air from the rear suspension .... its a handy feature when hooking up to heavy bumper pull trailers .... to unhook you just lower the jack to where it is on the ground, unlock the coupler, lower the rear of the truck, and drive forward .... I didn't like the brake control that came with our truck (a Tekonsha 9030), removed it and installed a Hensley TruControl .... if I had it to do over or if the Hensley goes bad, I'll probably go with a Prodigy
Jim
