Cummins12V98
Jun 08, 2016Explorer III
Cummins in Columbus, IN builds the 6.7 for RAM and Freightliner on the same assembly line. The only real difference is the adapter that mounts to the back of the engine that the trans will mount to. Oh and the Freightliner engines are painted red.
The Aisin is used by other manufactures in Medium Duty applications.
Ford uses their trans in the 650/750's now. The Allison they used to use was NOT the same trans as in the GM trucks. The 6.7 Cummins they used to use was the same as the RAM Cummins.
Someone can correct me but I have a fiend with a Kodiak and he says his Allison is different then the ones offered in the pickups. Other Allison applications like motorhomes can be different also.
