I have a 2018 Springdale 24bhwe and my Dometic air conditioner just stopped working. I bought the trailer brand new and have used it for a total if 30 nights. Everything was running fine then I no...
Agree with all of above. Loose/bad wire connections equals resistance. And resistance and current equals heat. And it doesn't take much resistance to create a lot of heat. Everyone with an RV, new or not, should disconnect from power, throw the battery disconnect switch, and tighten every screw in the circuit breaker panel and fuse panel, AC hot, neutral, ground, and 12 volt. I found about half of mine not tightened correctly.
