vanswey's avatar
vanswey
Melting wires
I have a 2018 Springdale 24bhwe and my Dometic air conditioner just stopped working. I bought the trailer brand new and have used it for a total if 30 nights.
Everything was running fine then I noticed the breaker at the campsite had tripped. I thot nothing of it and reset the breaker and the trailer worked perfectly again. About 6 hours later the ac stopped working. I checked the campsite breaker and it had not tripped so I opened the fuse panel in the trailer to see if the breaker had tripped which it did not. However I looked at the wires going into the buss and a lot of them looked charred or melted. Any ideas how this would happen? Thank you!!
  • I replaced my charger converter and discovered the inbound AC hot wire was never tightened. I know RV's are slammed together cheaply, but WTH, you shove the wire in and forget to tighten the screw???
  • I've found many a loose ground wire over the many years and many trailers behind me. Probably the most important wire of the whole bunch.
  • I agree on the loose wires. I go through all the wires at the panel in my TT at the beginning of the year and tighten them just to make sure this does not happen. Might be a good practice for your preventative maintenance check list each year. Sorry to hear this has happened.
  • Everyone loves those detachable cords, (I hate them) but how many check the tightness of the wires behind the inlet? My guess is that nearly all are never checked and that is a connection within the Styrofoam and thin plywood walls. My inlet fell to the ground when I removed it, all screws were completely loose.
    I have converted two different trailers to the twist lock cord connector. One was the stupid mouse hole, and the other had a door and a small compartment you were expected to wad the cord up and stuff it into.
    Now, I did the work myself and the connections on the back of the inlet and at the panel (and transfer switch on the last one) are all doubly tight. And I check them every year or so depending on usage. Every terminal, wire nut and connection in both the 12vdc and the 120vac system should be checked every year or more depending on how much the trailer or motor home gets used. Its all about rattling along down the road that loosens stuff up.
    Charles
