path1
Aug 21, 2014Explorer
Mercon and Mercon 5
From 2003 owners manual... "Some transmission fluids may be labeled as dual usage, such as MERCON and MERCON V. These dual usage fluids are not to be used in an automatic transmission that requ...
Mark Kovalsky wrote:path1 wrote:
What am I missing? Maybe 2003 info (older and outdated) and maybe newer stuff on market now?
What you are missing is that in 2006 ford discontinued licensing MERCON. They changed the specs for MERCON V to make it compatible with transmissions that used MERCON. MERCON V is now the correct fluid for use in any application that used to use MERCON.
