I ordered some fresh cab off amazon and it will be here in a couple of days.
For those of you who use fresh cab, do you only use it only when the rv will be vacant or do you leave it in there while using the rv as well? I ask because some of the reviews mentioned the strong odor, some thought it pleasant, some not so much.
Also it says it's only effective for 30 days. Do you change them out every 30 days or does it seem to last longer?
Finally, would this be a good product to put on top of the propane bottles (under the hard plastic cover) to dissuade mice from building a nest up there?
