rockhillmanor
Mar 23, 2015Explorer II
2012Coleman wrote:rockhillmanor wrote:In another post, you recommended Mold Armor from Lowe's. I used this yesterday and it works great!..
I've tried all the home remedies and none of them work on all what gets stuck to an RV awning. And btw, Those magic erasers are 'very' abrasive I wouldn't use it on the awning.
Bottom line I found that the Camco RV Awning Cleaner 'formulated' to clean an RV Awning and all the stuff that makes an RV dirty and is the only one that really works.
One spray bottle, No fuss, no muss and the awning looks like brand new when you're done.
http://www.amazon.com/Camco-41022-Awning-Cleaner-32/dp/B000BUOSES
If I can remember correctly I think I suggested that product for a forum member who had parked his RV and his 'roof' and top of awning was covered in black/green mold.
Mold Armor Blocker is a very harsh chemical and you really should not use it regularly. And you shouldn't have to because it actually prevents mold.
And do NOT use it on the side surfaces of an RV.
Camco Awning Cleaner won't hurt the awning. So you can use it often. The "newer" RV awnings have a very thin plastic type of awning material. You need to be careful with it.
44,056 PostsLatest Activity: Nov 19, 2013
