ShinerBock wrote:
transamz9 wrote:
ShinerBock wrote:
Off topic, but I am not a big fan of H&S Mini Maxx. Left many any of friends, family, and customers with blown head gaskets if the boost and injection timing is too aggressive and you don't have head studs installed. The other minus is that it doesn't tune the trans to handle the added power reliably like EFI Live, EZLynk, or MM3 does.
Can't tune the aisin so what do you suggest for my 16 Cummins? I'm talking to Calibrated Power through emails now about it. I've run my 2005 on extreme 100 % of the time towing heavy or not close to 10 years now and the engine has never had a hiccup and the stock factory trans is still pulling great but I've heard the aisin dont like added power.
The combination of a VG turbo that creates high drive pressure and the longer stroke of the 6.7L makes it a lot easier to blow a head gasket with aggressive timing and boost. Heck even in stock form this happened until Cummins reprogrammed the engine to not create so much low rpm cylinder pressure. The new ECM's of the 2013 and up trucks also helped because their hardware capabilities allowed for more fuel tables and other parameters.
I would say that talking with Calibrated is a good call. Nick knows way more than I do. If you are looking to delete then you might want to give Anarchy Diesel or Higher Power Performance. Either one will help you find what you are looking for. You may still be able to add power to your Aisin and just adjust how you drive with the added power. Some people say it bucks a lot with added power, and others say it is fine.
Nope, getting old and like the quietness of my truck. I'm wanting to tune with exhaust fully intact.
