RedRocket204
Apr 09, 2017Explorer
harley4275 wrote:
If the ledge you are talking about around the shower is the part where the shower walls meet the tub/shower floor pan, then leave it unsealed as that is where any water that may get behind will drain. The tub/floor pan has a lip behind so water cannot get in . The top of the walls should be sealed and the edges also.
Yes, exactly.
acritzer wrote:
Are slide out interior corners prone to cold morning condensation? The kids noticed some moisture on their pillows. I felt droplets, but seemed to be condensation.
Are you venting your trailer, even if it is cold outside? Humans expel a lot of moisture from breathing and condensation WILL form in a non-vented enclosed environment.
44,070 PostsLatest Activity: Jul 26, 2026
