- jus2shyExplorer
phipps33 wrote:
One more question, 2 of my tires require 35psi and 2 require 50psi. I'm guessing this means different load ranges. If they are different load ranges, should each load range be on the same axle?
Sorry for the questions, I'm trying to learn as much as I can.
Thanks!
There should be a numerical number noting the "Service Load Index" of the tire. Typically it's a number between 80 and 130. If you have different service load index values, then your tires aren't rated to carry the same load. The pressure thing could be an indicator of that very issue. - phipps33ExplorerOne more question, 2 of my tires require 35psi and 2 require 50psi. I'm guessing this means different load ranges. If they are different load ranges, should each load range be on the same axle?
Thanks! - BB_TXNomadI would prefer to have all tires the same. But as long as the bias ply is the same diameter as the radials I would not worry about it.
Checking the date on all tires is certainly a good idea. - harold1946ExplorerThe D14 is a bias ply and there is no reason to replace it just because it is mismatched.
- rbpruExplorer IIThe short version is D means diagonal placed belts and R means radially placed belts. The Tire and TT folks will tell you they will respond differently under load, so it is best to have them all the same type.
- phipps33ExplorerCould someone explain why this is bad? Not doubting your advice, I just like to know the reasoning behind for future reference.
I'm also assuming a tire size followed by D14 rather than R14 is a bias, correct? - phillygExplorer IIYes!
- darsbenExplorer IIyep
But you should check the tire date code on all the tires. ANY TIRE over 5-6 years old is a blowout just waiting to happen.
RV TIRES age out not wear out. If they are old they need to be changed no matter how much tread is left. EVEN IF they look brand new - fla-gypsyExplorerYes, get that corrected ASAP
44,052 PostsLatest Activity: Oct 12, 2025
