Just_Jeff's avatar
Just_Jeff
Modding an F-350 up or an F-550 down for TC
Given that you can get the same engine in an F-350 and F-550, which do you think would be better - beefing up the suspension and brakes on an F-350 so you don't need a custom bed, or buying an F-550 and customizing the bed to accept a TC?
It seems that, because of the custom work needed to put a TC on a flatbed and make it look nice, there's still several thousand dollars of work needed...but you get one heck of a nice vehicle out of it. I'd probably look at doing the SRW conversion so I could take it off-road without worrying about rocks/sticks between the tires.
But F-350s are much more common, and you wouldn't have to do much of anything to the bed for it to accept a TC with the proper COG and such, so that could be a significant savings over the F-550. That savings could then go into beefing up the brakes and suspension in the F-350.
Which one would be cheaper and easier?
It'll be several years, but after the kids are gone we're looking at swapping to a nice TC (over 11', slides, etc) on a truck capable enough for Forest Service roads so we can get to some back country sites. I'm thinking of something like these examples, and I really like boblynch's setup.
Any thoughts?
  • C&C 350,450,550 have different engines than regular 350 or 450's.
    While they are all 6.7, the C&C uses a different turbo and has 100 less HP and 140lbs less torque than the 6.7 regular trucks use.
    Having said that a C&C 450 or 550 is a good choice for hauling a heavy camper.
