plasticmaster
May 22, 2015Explorer
Moisture behind wall panel at bunk area
I have a Jayco 28BHS and have discovered moisture inside the wall panel at the bunk area. Obviously I need to find and fix the leak. I also need to remove the interior wall panels in that area to dry things out and clean potential mold. Does anyone know how the upper bunk is installed and how to remove it so that I can pull the wall panels down? Also, any tips on removing these panels?
