ScottG wrote:
westend wrote:
ScottG wrote:
Lysol wont kill mold (try it and you'll see). Bleach will.
Not quite accurate. Original Lysol that contains Phenol is a mildewcide. Same for original Listerine, it contained Phenol (Carbolic acid).
For the OP's situation, diluted bleach will kill any fungus and if the moisture issues are removed, there won't be any more mildew.
Totally acurate in my experience. I dont care what is in it.
I sprayed that stuff on the same dry mold on a car seat in an old car in my garage, every day for TWO WEEKS!
It did nothing! A little bleach and water mix kicked in overnight.
I' also tried in on some wet moldy wood during a house refurb. Worthless. Used straight bleach severa times and the mold was dead and gone.
Lysol = worthless to me.
Sorry, I should have put "original" Lysol in quotes so it was more prominent. I have never seen that offered in a spray so that might have been the reason your Lysol product did not work.
FWIW, here is another use of "original" Lysol: Years ago, while motor cycling in Mexico, I dropped the scooter and got a road rash on an elbow. When I returned home, it wouldn't heal. On the advice of a friend, I mixed 2 tbs of "original" Lysol in a gallon of warm water and soaked my elbow in this concoction for a week or so, once every day. The Lysol solution dissolved whatever was in the wound and it soon cured.
Yes, bleach is a great mildewcide. Use in dilution and let stand for 24 hrs. It is the amines of Sodium Hypochlorite in solution with water that actually does the work.
