candjmc's avatar
candjmc
Monitor issue
I just purchased a 11'6 " grizzly Northland
Brand new fridge electric jacks great camper bit heavier than my 9'6 "bigfoot but way more room.everything works great there was small leak on a fitting behind the toilet when I hooked up the water but as soon as completely pressurized it the leak was gone.I am not sure what the roof is made of maybe rubber.The only thing so far that's safety issue is the lp/carbon monoxide detector has no lights on it.I checked the fuses and idea's?
  • Try checking your fuse box, on mine, the same fuse runs the stereo and the co/lp dector
  • It's hard to get the volt meter on the wire
    But I'm pretty sure there was no power there
    Tracing that out would be chore I assume asall the
    Wire is hidden pretty well although only four feet from the inverter.
    The thin wire that attached tothe unit doesn't appear to be on the inverter anywhere
  • Yes if I do then the unit is toast if not
    There's wire off somewhere..I am not the best wiring person :)
