Barkoff wrote:
Bigbird65 wrote:
I leave my trailer plugged in 24/7 when at home. I check the battery water about once a month and rarely have to add water. I do not use a battery maintainer other than the WFCO WF-8955PEC converter that is in my trailer. No problems with the battery.
Just noticed I posted in the wrong forum.
Leaving your batteries plugged in does not overcharge them and shorten their life expectancy?
No, it increases life expectancy. It's not like your camera battery that you may have overcharged. There is a chemical reaction going on between the plates inside and the electrolyte. There is a float voltage recommended by your battery mfg. You should keep your batteries at that voltage.
Battery University, no tuition and no application required.
