altozwei's avatar
altozwei
More Battery Questions
Didn't want to hijack the other thread but we just got our first popup that actually uses a battery. The old trailer never had one. Don't know if the battery is dead but suspect it is (former owner says he hasn't used the camper in a couple of years). In looking at it, I see that it controls the emergency break-away controller for the trailer, making it a necessity. Since we will likely be buying a new battery we don't want to make mistakes with it.
Question 1) the break-away cable is very rusty. Should it be replaced?
Question 2) When we are not using our camper, do we remove the battery or just disconnect it and leave it in the box?
Question 3) If you remove it, do you keep it on a charger when not camping or is there some other way to take care of it when not in use?
  • We have a Tekonsha Voyager brake controller. Not what I would have purchased but it was free, it works great, it is very simple to operate, and it was easy to find the manual online. We keep our trailer at home, inside the fenced yard. As soon as we can get the garage cleaned out, it will move inside. Last summer, we got ants in our other trailer and I didn't think we were ever gonna get them out.
  • altozwei wrote:
    Really appreciate the helpful information. I'm reminded, too, that I need to go online and get the instructions for our brake controller. The seller gave us his and we had it installed but we didn't get any instructions with it. definitely several things here to put on the to-do list.
    Hope it's a proportional controller and not a time-delay, but at any rate it's better than nothing!
    Where are you planning to store the trailer? If it's anywhere that is easy for others to access (i.e. storage yard), I'd consider removing the battery and propane tanks when not in use to deter theft. Even along side of the house is prone to theft. One of the best things about most pop-ups we can store most in the garage at home!
  • Really appreciate the helpful information. I'm reminded, too, that I need to go online and get the instructions for our brake controller. The seller gave us his and we had it installed but we didn't get any instructions with it. definitely several things here to put on the to-do list.
  • You also need to ensure that the tow vehicle is not connected via the 7-way pig tail connection. This will send voltage back up to your brake controller and damage it, as per the instruction book that came with my controller.
  • RoyB's avatar
    RoyB
    Explorer III
    Some folks like to install a BATTERY DISCONNECT SWITCH. This makes it easy to disconnect the battery when not in use. It also lowers the possibility of you hooking the battery up backwards (VERY EASY TO DO) and blowing some fuses...
    Here are many views of the different battery disconnect switches
    DISCONNECT SWITCHES
    Click on the one you like for more info..
    I sort of like this idea using the disconnect switch that has a removable key - keeps the kids from playing with things... These can be mounted to the battery case lid or to the side of the battery case.
    I use a more expensive Battery control switch made by BLUE SEA in my mulitple battery bank setup that has multi-positions and the contacts are sealed iside. It also makes before break reducing the chance of internal ARCING on the contacts.
    Caution - If you pull the plunger out of the break-away cable unit just be aware it will be sending DC VOLTS to the electric brakes and will run down your battery pretty quick. Each electric brake Assy draws around 3 AMPS I think it is. Not good to leave the 12VDC on the electric brakes for any long length of time - might also burn out your brakes too... If it is going to take a long time reinstalling a new cable then pull the negative battery terminal to disconnect the source.
    Just my thoughts
    Roy Ken
    Yes, it should be replaced. It's not an expensive part.
    You can just disconnect it an leave it in the box
    It's up to you. Some people just store them, some keep them on a trickle charger.
    WoodGlue
