budwich's avatar
budwich
More fun with tires :-)
Lots of threads in the area, but I thought I would drop another on the pile. I have read a number of them and most have their opinion on brands and type (ie. st versus lt)... but was wondering about ply ratings. I have come across the "elevate" brand which indicates an "8 ply" rating on a "C" load range on a 14 inch tire. This seems some what out of "whack" as either the ply rating is over stated or the load range is understate. Am I misunderstanding things or are "marketeers" heading in a new "direction"?
  • CapriRacer is one of our tire engineers and certainly one to answer your questions.
    However a 14" C and D load range ST tire is nothing new or a new direction as you call it.
    We've had C and D load range ST tires since the ST tires first became available for light weight trailers (all types) many years ago.
    Actually the tire industry still use "ply rating" terminology in their mfg and dealer adds usually such wording as say a 6 ply rated load C tire. Six ply rated doesn't mean six actual plies.
  • I was suspecting a "mistype" in the ad... but I see in others that even carlisle appear to have "multiple rating" for the 14 in size (and others) with both C and D. Is this the "new direction" especially at the 14 inch size which seemed to not have many options left in recent times?
  • I suspect a mistype.
    PR (Ply Rating) and LR (Load Range) are directly linked with no deviation. The way to tell which is the mistype is to look at the max pressure. As a general rule, LR C have a max pressure of 50 psi, LR D = 65 psi, and LR E = 80 psi (Please note that some sizes have exceptions to this "rule".)
