Rbertalotto's avatar
Rbertalotto
MORE...Leveling Travel Trailer with air bags
So on another thread we went down a path of possibly using airbags or air shocks to level a travel trailer from side to side.
Looking under the trailer it appeared that a single airbag with an arm contacting both axles might be the way to go.
Today a buddy of mine that builds hotrods stopped by and we were looking under the trailer. He suggested I simply remove the bracket that supports the center link on the two leaf springs and insert an airbag here:
He suggested I'd need to install a panhard rod to stop the axles from shifting side to side
I believe a single panhard rod from the perch that will sit ontop of the center link with the airbag above would be sufficient.
Now I'm looking for input and comments from the engineer type folks on this forum. What say you?
  • Rbertalotto wrote:
    Here's one for you. I spoke to a "suspension engineer" and he suggested that I remove all the leafs but the main one and then add air bags between frame and axle. Let the airbag carry the trailer weight and not the spring. The single leaf spring would now be just to locate the axle.
    It was suggested if the trailer doesn't lower down enough, to heat the spring to remove temper. He offered that to level a trailer you can raise the low side AND lower the high side to give you much more range of level.....
    Interesting!
    Essentially, doing what your engineer suggested is the same as a trailing arm suspension. I think someone suggested that earlier. Using the leaf as the trailing arm is actually a pretty good idea, as it keeps you from having to fabricate anything.
    Probably wouldn't be a bad idea to do a little beefing up, such as tying the shackle mounts together side to side and such.
