- fallsriderExplorer
CavemanCharlie wrote:
That pretty much sums it up for me, too!
Ha, I want whatever is used and I can afford. :p - BillB800siExplorer
gmw photos wrote:
WoodGlue wrote:
My Lance trailer is aluminum caged w/ 2" thick extruded polystyrene that is laminated on both sides with Azdel. Azdel is not only a great insulator but it deadens the sound in an amazing way! It's also very expensive so it's typically only found in higher end trailers and campers. So, it's not for everyone.
The problem with wood in the walls is once ANY WATER gets in, you're setting up the perfect scenario for mildew and mold. No one wants to breathe mildew and mold!! The rotting comes along with poor maintenance or mis-assembly.WoodGlue
And I go back to two earlier posts about mold and mildew in a "plastic" ( azdel ) environment: if you think mold and mildew cannot occur in those plastic constructed spaces, leave your refrigerator off and closed up for a few months and come back and open it up.Once again, it needs to be pointed out that it's critical to keep water out of these laminated walls.....does not matter what they are constructed of.
Exactly GMW... Mold will grow anywhere...... Stop the leaks and you've solved the problem. - BillB800siExplorer
WoodGlue wrote:
Sometimes there's no accounting for taste!
WoodGlue
My God what a snobby answer. - C7XR7ExplorerLiving in the hail capital of the world stick and tin just isn't a good option. You rarely see stick and tin and if you do it is a dented mess.
- DieselXExplorerThe last camper we had was fiberglass, and after all the time I spent trying to keep that thing from delaminating...... On the way to trade it in the side peeled off and insulation went everywhere.
We walk through the campgrounds now and I see spots on most fiberglass campers that are bubbling from water. The gelcaps too.
They look great but I would pay extra not to have one again. - gmw_photosExplorer
WoodGlue
Once again, it needs to be pointed out that it's critical to keep water out of these laminated walls.....does not matter what they are constructed of. - JJBIRISHExplorerDo you think the aluminum tubing can’t crack??? Especially at a weld… how would they repair that…
- WoodGlueExplorerMy Lance trailer is aluminum caged w/ 2" thick extruded polystyrene that is laminated on both sides with Azdel. Azdel is not only a great insulator but it deadens the sound in an amazing way! It's also very expensive so it's typically only found in higher end trailers and campers. So, it's not for everyone.
WoodGlue - TurnThePageExplorerOne disadvantage of the aluminum sided trailers is sound penetration. If you're in mine, you can hear EVERYTHING going on outside. I'm guessing the more solid walls of fiberglass or equivalent with block insulation would be quieter.
This may sound a little harsh, but I get very tired of the people that keep whining about wood rot and water intrusion. They come off as maybe intentionally ignorant and perhaps not willing to put forth the effort to maintain their RVs in the first place. Wood framing and flooring does NOT equal water intrusion. My cheap, sticks and tin trailer lives outdoors 365 days a year. It currently has a foot of snow on it with nary a leak or speck of wood rot in its 10 year life. - JJBIRISHExplorer
smkettner wrote:
Who makes aluminum frame and aluminum siding?
Too many posts about fiberglass troubles for me and I am indifferent to the "smooth look".
SunnyBrook Sunset Creek
44,056 PostsLatest Activity: May 04, 2014
