- rbpruExplorer IIIf I wanted a bomb proof rig I guess I would by an Airstream but I prefer something I can afford. ;)
- ScottGNomadThey sell a lot of stick and aluminum because they're cheaper, not because they're better.
I will NEVER again have a stick and tin RV. Now if they used aluminum studs and strong, flat aluminum walls (like some HR products), I would be interested in those. But the thin corrugated material.. No way.
BTDT! - WoodGlueExplorerSometimes there's no accounting for taste!
WoodGlue - JEBarExplorerthe Jayco Jayflight line has been the number one selling line of campers in the US for over 10 years .... the top three selling lines are all have aluminum siding
Jim - AlbertaNewbieExploreragreed, rv shows cater to entry level more than high end, plus the shows are in the off season where most dealers dont want to have more expensive inventory hanging around to pay finance charges on.
- WoodGlueExplorerGive me fiberglass any day!
I think that wood negates the weight factor of a stick and tin vs aluminum and fiberglass trailer!
WoodGlue - skipncharExplorerSeems to depend on the make and model you're looking at.
- LowsuvExplorerThe last time I was buying I was a diligent student .
I studied every detail for a year before buying my 4th ( and current ) RV .
Nash and Komfort offered some models with a choice of the corrugated aluminum siding or for more money the " fibreglass " smooth sided .
In the 21 - 22 foot size the aluminum skin trailer was 400 pounds lighter .
This was true for both brands .
For those f150 fans an aluminum sided trailer can help their towing experience . - SooperDaddyExplorerAluminum sided trailers are tried and true...build like a house and this type of construction with wood framed aluminum skin has been around since the 1940's. If you're an Ecological Freak...these types of trailers are about 80 percent recyclable! They are inexpensive entry level RV.
The smooth sided trailers and rv's are more labor intensive to build, takes more skills and steps to build, use more expensive construction involving plstics, glues, and lamination, foam core walls,and welded aluminum frames. A bit more $$$.
WOOD FRAMED JAYCO
ALUMINUM FRAMED JAYCO
- colliehaulerExplorer IIIMost RV shows have a lot of entry level campers at them. Most entry level campers are stick and tin construction.
44,056 PostsLatest Activity: May 04, 2014
