MFL
Nov 01, 2015Nomad II
Yes, you are mostly right, about the nickel too. I am surprised they continue to make pennies. If you look at brochure unloaded weights, they likely don't include batteries or propane, but may not show the added wt of other options. Some trailers have a large CCC, so a big GVWR. In this case you may be closer to figure UVW, plus the 1,000/1,500 lbs, that you normally add to your trailer.
Jerry
Jerry
