dodge_guy
Nov 02, 2015Explorer II
On my trailer the UVW in the brochure was only different by about 150 lbs. the only things that were options on my trailer were the "sunroom" option (bigger windows and 3 skylights) and a spare tire. everything else was standard!
Like the OP said, if you know how to do it using the "dry weight" is the way to go. I could easily say "no one tows around a trailer at it`s full GVWR!) my trailer has a 4100lb CCC. I still have 2k lbs left before I hit that. so it can work both ways.
Bottom line do you homework and know what you are doing! for a family of 4 or 5 I say add 1200-1500lbs to the dry weight. if you can`t tow this then you need to look at a different trailer!
