Gdetrailer
Nov 02, 2015Explorer III
GrandpaKip wrote:
Well, some of you got my point that UVW is not a useless figure. I cannot imagine even the noobiest noob thinking that they won't add anything in a camper and increase the weight. But if they are that dense, nothing anyone says to them will make sense. If I only go by gross weight rating, there are a bunch of campers that exceed my truck's rating. However, when the CCC is 2000 to 2500, or even 3000 lbs, I know I am never going to load that much in a 20-23 foot camper.
I'm probably up to a dime, now.
You sir have identified my point..
Many trailers which do have very large CCC ratings often well exceed the TOW VEHICLES Cargo rating and not only that the COMBINATION rating.
In some states you might have the "luxury" to do this with a CAMPING TRAILER but some states (like mine) CAN not only fine you but make you park your rig along the road until you correct the combination weight FOR NON RV TRAILERS like flatbed and utility trailers..
Additionally towing flat bed and utility trailers in my state exceeding 17,001 lbs GVWR COMBINATION you now are REQUIRED to have your HEALTH CARD (IE yearly doctor signed health card), YOU ARE REQUIRED TO HAVE THREE TRIANGLES OR FLAIRS AND YOU ARE REQUIRED TO HAVE ONE FIRE EXTINGUISHER.
You ARE more than welcome to justify your choice, but I myself will error on the safer side..
I am not so vain that I must prove my manliness or how macho I am by oversizing my RV for the tow vehicle I have.
Yes, using the GVWR as a sizing tool you WILL "eliminate" some choices in trailer size.. But what you lose in the larger trailers you gain so extra capacity and capability of your vehicle.. Makes for a nicer tow when you are not having to count potato chips..
Sorry if you don't like it.. If you must have that larger trailer then it is pretty much a no brainer to consider a better equipped vehicle for the job..
Yeah, my 3/4 ton truck has 3415 lbs of cargo capacity and of that capacity I am only using 1,200 of that capacity including passengers.. The result is I do not need WD at all to carry my trailer and I am not having to decide which child must stay home..
