2012Coleman
Nov 03, 2015Explorer II
Oaklevel makes a good point - whatever numbers you are using to calculate capacities are only a guess. If your guess doesn't give you significant comfort from using the gross numbers, then time to get to the scales.
And yes, total newbies DO think that their 1500 with P tires and a magical tow capacity of 9000 lbs can tow a 31 ft TT weighing 8500 lbs - dry. If you don't think so, then you don't read the forums here.
And no matter how much experience you have, you cant "see" what stuff you put inside your TT weighs.
