wsc7050's avatar
wsc7050
More solar questions!
I'm really sorry to be posting again about my solar questions! I'm still concerned about my setup. Thanks in advance and for all the previous help!
I have a zamp zs 7a controller in my Nash 25 c travel trailer. It is connected to a zamp 100watt panel mounted on roof. Here are my questions.
1. When I disconnect the negative terminal and the panel has sun, I can turn on lights and the charger lights are still on. Is this normal? Once I pull the fuse for the panel, nothing works. When I replace the fuse with the negative still disconnected, nothing is powered either. Seems strange to me.
2. The controller seems to keep charging the batteries even once the charge light comes on. Which is around 14.2 v.
I'm aware that there is an equalization period. I have witnessed this as the charged light is not on and voltage will rise to 16.2. Today I watched this happen for about 30 minutes and figured it would run its course then drop to either 14.2 or 13.6. I wanted it to run its course so I left for two hours. When I returned the charged light was on, but the battery was at 15.6 and the charger was still putting out 1.5 amps. This also seems strange and the voltage too high. Am I missing something?
Thank you in advance for any info you have. Merry Christmas to all. Matt
