parker.rowe wrote:
Bedlam wrote:
ATF soaking it overnight has freed things up for me in the past. Marvell Mystery Oil and PB Blaster have also worked after soaking in. Are they over run and jammed or just corroded in place? If corroded, a couple of whacks with wood block from the top and bottom may free the threads.
I second ATF.  I have had more luck freeing stuck engines with ATF and PB than motor oil.
Should work similarly with a jack, if it can be unstuck.
Ok, I’ll pick some up this afternoon and dump that down it too.
