HadEnough's avatar
HadEnough
More Stuck Camper Jacks
Seems to be a common problem with sticking camper jacks.
Two of mine are stuck. Trying to get them unstuck ASAP as they are delaying a trip.
I bought 2 new power heads for the better part of $1000 and that wasn’t even what was wrong! Ugh.
I installed the new heads and still the clicking of the clutches or gears slipping.
So now it’s obvious my legs themselves are stuck.
I bought a drill adapter on Amazon for Rieco Titan jacks for $26 and it was too small. Didn’t fit. Losing a ton of money and time here.
What other ways have you used to link a drill up to Rieco Titan camper jacks? A socket or something?
I want to use a nice, high power drill to get these legs moving and to raise and lower them many times, apply grease, etc.
Thanks!
  • ATF soaking it overnight has freed things up for me in the past. Marvell Mystery Oil and PB Blaster have also worked after soaking in. Are they over run and jammed or just corroded in place? If corroded, a couple of whacks with wood block from the top and bottom may free the threads.
  • Ok, I was able to mate a drill to the thing that needs to spin at the top of the jack. I broke the tip off a 1 inch spade drill bit and used it like a huge flathead screwdriver.
    No good.
    The leg won’t budge. I super liquid wrench down it before. In desperation, I dumped a ton of motor oil down it today.
    Nothing. 2 legs are completely frozen and won’t budge.
    Any other thoughts on how to get them moving again?
