cewillis wrote:
Reddog1 wrote:
Maybe someone can explain how the truck can squat 3", and be raised back with anything that is not adjustable?
Anything that is fixed, is just that, fixed. If you have a given truck, and load it with five different weights, no fixed spring, Stable Loads or shock will bring it back to the original height. Air bags will.
For those that have a problem with airbags, they might consider how many big trucks are on the road with them.
My top overload brackets are adjustable in ~1" increments, mostly not needed after initial setup for a given camper.
Big rigs run on paved, level roads 99.9+% of the time. Others of us don't.
Big rigs like logging truck are mostly still spring suspension. The OTR like stated are mostly on paved or graded roads and not out running the really rough stuff.
Also the lower Stable Loads can be taken in and out with a ratchet. Take look at the
Stable Loads This is the type you use if you don't have an upper overload. When you are not using the camper or loading the truck down just swing them out, then when needed swing them in.
