wintersun wrote:
I would spend $400-450 on a set of SuperSprings. A single overload leaf on each side costs $400 and adds 1400 lbs. of support or for $50 more you can get a pair of leaves for each side. It took me an hour to install them on my Chevy truck.
You want the springs to support the load and the shocks to dampen the motion of the springs, same as when the truck was engineered by the manufacturer.
And on certain trucks like mine, they gouge you for the bracket kit for an additional $75. Go to a spring shop and get proper overloads installed for less.
This is a custom 5 pack installed on 07 Dodge for the same cost as SS. And you can set them up to engage right and avoid spending on overpriced Stable Loads.
Gman
