billtex wrote:
homefor2 wrote:
I added air bags and found that they lifted the truck off the overload springs and really made a side to side sloppy ride.
That's exactly how NOT to use airbags...too much psi and you leave the overloads=rock and roll.
Enough psi to bring you to level...without leaving the overloads is what you want.
I agree with this, but will add, if your overloads do not have the correct adjustment, you may never be satisfied with the air bags. Personally, I do not have overload springs, just airbags. I have no issues with a side to side sloppy ride. I did have the side to side sloppy ride before I installed the 19.5 tires. The stiffer sidewalls make a huge difference.
