4x4ord's avatar
4x4ord
Explorer III
Oct 21, 2013
Motor Swap
I have a 1993 GMC 3500 that is in extremely nice shape. It has a 4.11 rear diff and a 5 speed standard transmission. I am giving it to my daughter's boyfriend and we plan to replace the 6.5 diesel with another engine.
I have told him the easiest option would be to put a new Peninsular 6.5 diesel in it. If we replace the turbo and fuel injection system this will likely cost around 10k. The new engine would be a 2013 6.5 tuned to I believe 300 HP.
Option 2 is to purchase a wrecked 2005 Ram with the Cummins in it for $2500. The truck has 155,000 miles on it. I like this option but realize it may be quite a project. Anyone know what all is involved in doing this swap?
Some things I am pondering before committing to this project are:
The standard GM transmission should bolt up ... what about the clutch?
Clutch linkage?
Clearance? Will we need to install a lift kit?
Will the transmission need to be moved back? Have to cut hole in floor board? Shorten driveshaft. Extend transfer case linkage?
What about the after cooler mounting?
Accelerator pedal - likely electronic on the Dodge - I guess it will have to be moved and mounted somehow?
What about cold start set up? Ignition Switch?
