swimmer_spe's avatar
swimmer_spe
Motorcyle rack behind trailer?
I have a 1998 Rockwood Ultralight 24 footer.
I own a motorcycle that weights 400 lbs. I have seen local stores that sell racks that go into a 2 inch receiver that are for hauling a motorcycle.
Anyone ever do this? Would it be safe to do?
  • Ivylog's avatar
    Ivylog
    Explorer III
    Putting that much weight on the back of your TT will take you to the scene of the accident... way too much weight off the tongue before the bouncing broke the hitch and put the cycle on the ground.
  • MFL wrote:
    Most motorcycle carriers for receivers, are marked NOT FOR TT OR FW USE. They are designed for truck or motorhome receiver use, where bounce is not an issue.
    Jerry
    I never read the full application of it, just saw it in a store and wonder about using it. What if it does not say that?
  • Most motorcycle carriers for receivers, are marked NOT FOR TT OR FW USE. They are designed for truck or motorhome receiver use, where bounce is not an issue.
    Jerry
